JS error on php page
Thread begun 5/28/2011 8:57 am by kp006274029 | Last modified 6/01/2011 6:39 am by Jason Byrnes | 2372 views | 3 replies |
kp006274029
I used the workaround for the greyed out populate list array issue. I than moved the code back from above the doctype and back to the origional location under the title tag, however when I view the page on my testing server. I get a JS error and the child list isnt populated.
looking at the source of the web page, I'm getting the following notice:
Notice</b>: Undefined variable: m in <b>C:\HostingSpaces\admin\happys.co.uk\wwwroot\admin\items_Insert.php</b> on line <b>103</b><br />
Please find attached the items_insert.php page.
Many Thanks
KP
I believe this may be caused by the names of the select lists.
try using different names for the select lists such as "itemCategory" and "itemSubcategory"
kp006274029
Hi Jason,
Figured it out, it was because one of the rows in my subcategory recordset had a blank foreign key which was meant to link to the parent category recordset. Deleted that row and it now works.
KP
P.S: Instead of moving the code for the dynamic array from one place to another as a workaround, it's easier just to detach the page from the template and than reapply the template to the page if required.
Ok, glad to hear it is working.
