MRT Manage Relational Table
Thread begun 5/28/2011 12:01 am by Jim E D | Last modified 12/29/2011 9:14 am by Jason Byrnes | 9013 views | 25 replies |
Jim E D
I've got three categories tables (Markers, Categories, MarkerCategories).
I've followed the thread by Andrew Read and modified accordingly but I still get an exclamation mark in server behavior.
First error message says: "The column name "true" was not found.
Second message says: "The column name ".((isset($_SESSION["WADA_Insert_markers"]))?$_SESSION["WADA_Insert_markers"]:"") ."" cannot be found.
Restarted this process many times using all options within the MRT tools - still not success. Thanks in advance for your assistance.
Also, I'm wondering why lines128-148 and 154-174 end up being the same code?
this_is_me
same here - the column name "false" was not found
I have a red exclamation mark next to "Manage Relational Table" and clicking on it the above mentioned error message pops up, followed by:
The column name "".$_SESSION['WADA_Insert_products']."" was not found.
Nothing is inserted after starting from scratch.
On the update page there is also a red ! next to "Manage Relational Table"
this_is_me
Originally Said By: this_is_me
For the topic of nothing being inserted:
Just found out that the MRT is put BEFORE the Insert Server behaviour, so the session variable cannot be retrieved in time.
I'd call this a serious bug in the code.
danny405167
I am having the same issue with Manage Relational Table
I am also receiving the same errors as mentioned above.
1) Red exclamation on the Manage Relational Table
2) The column name "false" was not found
3) The column name
".((isset($_SESSION["WADA_Insert_premium_hrs"]))?$_SESSION["WAD_Insert_premium_hrs"]:"" ."" was not found
I found the following thread but I am still unable to make it work. Can you please help
showthread.php?t=17763&highlight=Andrew+Read&page=2
danny405167
Please fix the bug in MRT Server Behavior code
It seems that I am not the only one who is having the same problem with using MANAGE RELATIONAL TABLE Server Behavior. I tried to looked for a solution yesterday and this morning but nothing has being useful in trying to solve the common issues of
3) The column name
The solution that some one posted under the following link did not work either
show...3&postcount=17
Some one also tried using the link above and got the same errors.
I wish you had a simple tutorial on how to use the Manage Relational Table Server Behavioir.
I have followed the diagram that you have on your MRT(Manage Relational Table)
MAIN TABLE
***** Welders ****
prim key ----> welderID
nameF
nameL
status
empType
spcPreHrs
RELATIONAL TABLE
**** Premium_hrs ****
prim key ----> recID
WeekEndings
forgn key ---> dayID
forgn key ---> welderID
hrsReg
hrsOvrT
hrsEarn
hrsDblt
OPTIONS TABLE
**** Weekdays ****
prim key ---> dayID
dayName
STEP 1 of the Wizard
***Settings***
Trigger: Button: Insert pressed
***Database***
Connection: DB name
Relational table: premium_hrs
***After insert***
Go to (optional: premium_hrs_Results.php
Pass original querystring (unchecked)
STEP 2 of the Wizard
***Main table join***
Foreign key column: welderID
Data type: Numeric
Key Value: <?php echo $_SESSION['WADA_Insert_premium_hrs']; ?>
STEP 3 of the Wizard
***Options table join***
Foreign key column: dayID
Data type: Numeric
Key Value: 'WADA_RepeatID_dayID' in Repeat Selection(weekDays, 1)
STEP 4 of the Wizard
I left the default settings as
***COLUMN*** ***Type*** ***Value***
dayID Numeric Automatically bound joined key field
welderID Numeric Automatically bound master key field
And I still get the same errors
3) The column name
Could I please get some type of support.
sublucentBeta Tester
Same Issues
Hello,
I'm having the same issues:
3) The column name "".$SESSION['WADA_Insert_print'] ."" was not found
Can't seem to find anything that works searching the forums.
Thanks for your help!
