Universal email - can't submit form
Thread began 5/27/2011 7:35 am by simon.riffou408873 | Last modified 6/07/2011 8:45 am by Jason Byrnes | 1613 views | 3 replies |
simon.riffou408873
Need help with this webpage:
contact-test.php
I get the following errror:
Warning: require_once(Mail.php) [function.require-once]: failed to open stream: No such file or directory in C:\HostingSpaces\feric\fpsuite.ca\wwwroot\testserver\fpsuite\webassist\email\PEAR_Mail_using_SMTP_php.php on line 115
Fatal error: require_once() [function.require]: Failed opening required 'Mail.php' (include_path='.;C:\php5\pear') in C:\HostingSpaces\feric\fpsuite.ca\wwwroot\testserver\fpsuite\webassist\email\PEAR_Mail_using_SMTP_php.php on line 115
this error means that the path to pear that was entered in the universal Email server behavior for the SMTP server is not correct.
contact your host to determine the correct path to PEAR that should be entered.
simon.riffou408873
Pear mail on Contact form
Hello,
Need help
This page:
contactus-simple.php
gives the following errror on submit.
Warning: require_once(C:\php5\pear\Mail/mime.php) [function.require-once]: failed to open stream: No such file or directory in C:\HostingSpaces\feric\pit.fptransport.org\wwwroot\testserver\contact-form-test\webassist\email\PEAR_Mail_using_SMTP_php.php on line 200
Fatal error: require_once() [function.require]: Failed opening required 'C:\php5\pear\Mail/mime.php' (include_path='.;C:\php5\pear') in C:\HostingSpaces\feric\pit.fptransport.org\wwwroot\testserver\contact-form-test\webassist\email\PEAR_Mail_using_SMTP_php.php on line 200
Double check with your host the pear Mail package has been installed on the server.
this error suggests that pear is installed, but either the Mail addon package is not installed, or your path to pear is not correct.
