calculations
Thread begun 5/27/2011 12:23 am by QuiruNet | Last modified 5/31/2011 11:05 am by Jason Byrnes | 5484 views | 13 replies |
QuiruNet
calculations
how can i multiply times 100 the GRANDTOTAL?, my bank as me to this multipication to check out to payment plataform. i try it in Object Ecart but I can not do the calculation because i can not put the shipping total, in the shipping formula i have two rules with a flat rate.
<?php echo WA_eCart_DisplayMoney($tenacitas, $tenacitas->GrandTotal()); ?>
use the following code:
<?php echo(WA_eCart_DisplayMoney($tenacitas$tenacitas->GrandTotal()) * 100); ?>
QuiruNet
no decimal
it do the multiplication but is a round number, how i can do to show the decimals.
use this code:
<?php echo(WA_eCart_DisplayMoney($tenacitas$tenacitas->GrandTotal() * 100)); ?>
QuiruNet
it is working
i have the same problen with ecart4 but in asp you can help me to the same operation the code is:
<%=WA_eCart_DisplayMoney(tienda, WA_eCart_GrandTotal(tienda))%>
thanks
<%=WA_eCart_DisplayMoney(tienda, WA_eCart_GrandTotal(tienda) * 100)%>
QuiruNet
bank news
the bank tolme if we can send the total with out decimal spaces, how i can do it?
I wrote this code you sendme:
<?php echo(WA_eCart_DisplayMoney($tenacitas, $tenacitas->GrandTotal() * 100)); ?>
an for example the number diplay like this: 280.50, but the bank plataform need like this 28050
Please can you send me the answer for asp too:
PHP:
<?php echo(str_replace(".", "", WA_eCart_DisplayMoney($tenacitas, $tenacitas->GrandTotal() * 100))); ?>
ASP:
<%=Replace(WA_eCart_DisplayMoney(tienda, WA_eCart_GrandTotal(tienda) * 100), ".", "")%>
QuiruNet
What i need is like this (example): 1490, i wrotte the code you give me and display like this: 1490,00 &#8364;, and need only like this: 1490
PHP:
<?php echo(str_replace(".", "", $tenacitas->GrandTotal() * 100)); ?>
ASP:
<%=Replace(WA_eCart_GrandTotal(tienda) * 100, ".", "")%>
