Redirect issue - Cannot modify header information (already checked for blank lines)
Thread begun 5/26/2011 5:10 pm by YellowCircleWeb | Last modified 5/27/2011 6:28 am by Jason Byrnes | 3539 views | 3 replies |
YellowCircleWeb
My page is not redirecting properly after an update. I've viewed multiple postings in the forums about this and tried different solutions, all with no luck. I've also double checked that there are no blank lines between opening and closing PHP tags and after 30 minutes of examining the code I can't see any.
I've turned all error reporting on and the exact error I'm getting is:
Warning: Cannot modify header information - headers already sent by (output started at /home/sites/esm.uk.com/public_html/esmfreelancers/assignments-update.php:77) in /home/sites/esm.uk.com/public_html/esmfreelancers/assignments-update.php on line 186
I've looked at line 77 in the code and that's a security assist check to make sure the user is logged in. I tried removing that piece of code, but I still get the error. I've also looked at line 186 - that's the line that tells the page to re-direct. Nothing I can see wrong there either.
I've attached a copy of my page. If someone could help me with this I'd be most grateful.
right, this code at line 77 - 81:
if (!WA_Auth_RulePasses("Logged In As Admin")){
WA_Auth_RestrictAccess("../esm-staff-login.php");
is checking to make sure the user is logged in, then the WA_Auth_RestrictAccess() function is trying to use the header operation to redirect the user.
this cannot be at this point in the page because there is alrteady HTML content.
the header function can only be used before the doctype or any other output is made to the page, it's not just blank loines that cause the error, it is ANY output. that can be a blank line, HTML tags, HTML comments, javascript, a php echo or print statement.
your page access check needs to come before all other HTML on the page.
YellowCircleWeb
Thank you very much Jason.
I moved all the PHP code above the DOCTYPE and it worked. I'll remember this in future.
you're welcome.
