Error installing SecurityAssist 2
Thread began 5/26/2011 4:31 pm by Larry | Last modified 6/03/2011 10:28 am by Jason Byrnes | 2365 views | 8 replies |
Larry
I just purchased the SecurityAssist 2 extension, when trying to install the new version, I receive the following message,
"This extension requires the following products:
Dreamweaver 10 or greater
The extension will not be installed."
I then click on "ok" as that is the only option I have.
I should mention here that I own just about every extension from WebAssist along with most of the Pre-Built PHP Solutions.
I did uninstall SecurityAssist version 1 before trying to install SecurityAssist version 2.
I have also deleted the "WinFileCache.dat" file.
My operating system is Windows Vista Home Premium, running Dreamweaver CS3, which are both included in the system requirements for using/running SecurityAssist version 2.
Any and all help/information as to why I can't install SecurityAssist version 2 are greatly appreciated.
I have included two screenshots with this post.
Thank you
Larry
I just wanted to add here that I also tried installing SecurityAssist 2 on my laptop, which is running the same operating system and the same version of Dreamweaver, which is CS3 without any luck, the same exact message appears, and I cannot install this extension.
Larry
Hi Jason,
Thank you for the prompt reply, I did login to my support history, but did not see any support ticket for this issue. Am I missing something?
Larry
should be there now.
Larry
Thank you Jason, I have updated the information asked for, I will now wait for a response.
Larry
FrankJay
Please share results
Hi Larry,
I too am experiencing the same problem and will highly appreciate you posting the results of your support ticket. Thanks
Larry
Hi Frank,
Did you get any help or an answer to this yet. Jason helped me through my support ticket, the answer was downloading a new extension that Jason provided.
I see I am not the only one that had this issue.
Larry
gjy5199349551
Hi All
I too had purchased SA2 expecting it to work with my CS3 install and though it installed correctly with CS4 the older version presents errors. I submitted a bug ticket and was directed to post here as well, so here I am.
