CSS Form Builder Has Dreamweaver locked up!
Thread began 5/26/2011 12:37 pm by latellogroup375248 | Last modified 6/22/2011 8:00 am by Jason Byrnes | 2067 views | 5 replies |
latellogroup375248
After I hit finish on CSS form builder (after I removed the .dat and rebooted) I now get this message:
ErrorGenerating: buildColumn
TypeError: ShowIfObj.setParams is not a function
Then after closing this error window about 6 to 8times in a row to get it to go away a longer message from dreamweaver pops up and says:
The document contains JavaScript code for a widget that no longer exists. If you don't remove the code the browser might display JavaScript errors when loading the page. Would you like for Dreamweaver to find all instances of this code for you.
Then it gives a list of differnt code has YES NO buttons a the bottom. If you click yes it list all the instances and the haphazadly displays the form I tried to insert. If you click no it just show the haphazard display of the form I tried to insert.
Any help would be appreciated on this
I am using CS4 with windows 7 Ulitmate 64 and I own all of the WebAssist stuff
see the known issues section of the Form Builder Download Center page for a fix to this issue.
latellogroup375248
Thank you for the directons.
Your help is appreciated
you're welcome.
tomaj
Error generating: buildColumn
Hi janson ,
I get this message when FormBuilder 1.0.2
(Error generating: build column
TypeError: ShowIfObj.setParams is not functional)
can you help me please.
Please, no ticket, I have one and you have their support appears to have no time for my problem since yesterday and let me wait.
