Discount question
Thread begun 5/26/2011 6:04 am by info4753 | Last modified 6/02/2011 6:52 am by Jason Byrnes | 3916 views | 8 replies |
info4753
Discount question
I have the following discount rule for wines (PRODKATID = 7) in our shop:
10% discount if more than 95 bottles of wines are in the cart:
Number of items with PRODKATID of 7 >= 96
Now I need to exclude all wines with a special field value of 1. Means no discount on wines with Field "Primeur" = 1
I've already added another Column "Primeur" in the cart and add the field value from the recordset when adding to the cart.
Now how do I extend the rule to:
Number of items with PRODKATID of 7 AND Primeur of 0 >= 96
Thanks for any help.
in the discount, select to use a custom trigger, for the custom trigger use the following code:
$this->ConditionalTotal("Quantity", "PRODKATID", "7") - $this->ConditionalTotal("Quantity", "Primeur", "1") >= 96
this will return the total number of items where PRODKATID = 7 Minus the total number of items where Primeur = 1
info4753
The total discount is still wrong. Here is the rule:
//eCart Rule
function WAEC_eCart_Weinrabatt10() {
$totalDiscount = 0;
if (true && ((( $this->ConditionalTotal("Quantity", "PRODKATID", "7") - $this->ConditionalTotal("Quantity", "Primeur", "1") >= 96 )))) {
$totalDiscount += ($this->ConditionalTotal("TotalPrice", "PRODKATID", "7") * 0.1);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
What happens is that if there are >= 96 bottles of non primeru wines in the cart, the total discount (10%) is counted on the non-primeur AND the primeur wines in the cart.
Furthermore I tried to extend the other discount(s) but received a parse error:
(Discount of 3% for 24 - 47 bottles of wines):
Current rule without primeur wines:
//eCart Rule
function WAEC_eCart_Weinrabatt3() {
$totalDiscount = 0;
if (true && (($this->ConditionalTotal("Quantity", "PRODKATID", "7") >= 24) && ($this->ConditionalTotal("Quantity", "PRODKATID", "7") <= 47))) {
$totalDiscount += ($this->ConditionalTotal("TotalPrice", "PRODKATID", "7") * 0.03);//Result
//eCart Rule
New rule with primeur wines, causing parse error:
//eCart Rule
$totalDiscount = 0;
if (true && ((( $this->ConditionalTotal("Quantity", "PRODKATID", "7") - $this->ConditionalTotal("Quantity", "Primeur", "1") >= 24 )) && (( $this->ConditionalTotal("Quantity", "PRODKATID", "7") - $this->ConditionalTotal("Quantity", "Primeur", "1") <= 47 )))) {
//eCart Rule
thanks for any additional help in advance :-)
info4753
May I push this thread up again? I do need some support in this issue. Thanks in advance :-)
instead of changing this in the code, you should do it in the discount portion of the eCart object
for the first rule, set the trigger to a custom condition:
then set the calculation to a flat rate and enter this code:
($this->ConditionalTotal("TotalPrice", "PRODKATID", "7") - $this->ConditionalTotal("TotalPrice", "Primeur", "1")) * 0.1
for the 3% off on 24 - 47, enter the following for the custom trigger:
($this->ConditionalTotal("Quantity", "PRODKATID", "7") - $this->ConditionalTotal("Quantity", "Primeur", "1") >= 24) && ($this->ConditionalTotal("Quantity", "PRODKATID", "7") - $this->ConditionalTotal("Quantity", "Primeur", "1") >= 47)
($this->ConditionalTotal("TotalPrice", "PRODKATID", "7") - $this->ConditionalTotal("TotalPrice", "Primeur", "1")) * 0.03
info4753
Thanks a lot Jason, I'll give try on this and give you a feedback.
you're welcome.
info4753
Works like a charm :-)
glad to hear it is working.
