number of times I can use powerstore
Thread begun 5/25/2011 8:28 pm by eladgraphics386618 | Last modified 5/27/2011 12:15 pm by Jason Byrnes | 3107 views | 5 replies |
eladgraphics386618
Hello
" PowerStore can be activated on one domain for testing and one live domain. If you are moving PowerStore to a different domain, click the Reset Activations button from the Download Center to use your serial number again."
I am a little bit confused here. I bought the powerstore to create sites for all my customers, is the test above means I can use it only for one live domain? or I can use it like the extensions as many times as I want to.
eladgraphics
the license for all of the PHP Solutions allows you to use them on one domain, if you wish to use the solution on additional domains, you will need to purchase an additional license.
We offer a volume licensing program that gives a significant discount on additional licenses, see the volume licensing program detail here:
volume-licensing.php
eladgraphics386618
hello
On setting up the powerstore on localhost I have
an issue with "cURL". How can I fix that. I did not have that issue on live server
thanks.
Still waiting for your call for the Theme-it problem.
thanks
eladgraphics
you will have to enable cURL in the php.ini file
in the php.ini file, find the following line:
;extension=php_curl.dll
and remove the ; at the beginig:
then restart the server.
eladgraphics386618
powerstore multiple usages
Hello
Thanks for the quick reply. I have checked the volume discount and is over our budget. Do we have the 14 days money back guaranteed on this product?
thanks
contact the sales department at sales@webassist.com for any refund questions.
