SSL is not redircting my powerstore 4 pages
Thread begun 5/25/2011 2:57 pm by alexcubs413730 | Last modified 10/06/2011 5:27 pm by Jason Byrnes | 5876 views | 7 replies |
alexcubs413730
I"m using go daddy's ssl. It only works when i type in https<---. Go daddy tech told me that I need a script to redirect my wed pages. Can some one help me understand this better.
Power store should automatically redirect the checkout pages to the SSL server, the other pages wont need to be protected by SSL.
you could force the entire site to use SSL through an htaccess rule, see the page for details:
force-ssl-htaccess.html
austin322980
Still getting a error after the .htaccess
Good afternoon,
I am still getting a SSL error in the URL bar that resources on the site is unsecure. I have already done the .htaccess code:
RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://www.example.com/$1 [R,L]
The SSL that I am using is 256. Attached is a snap shot of the error. Thank you for your feedback.
this error occurs if you have assets on the page such as images that use a fully qualified URL using the unsecured HTTP protocol. For example:
<img src="http://mydomain.com/imges/picture.jpg" />
If you have any assets where you specify a full URL, you will need to use the HTTPS protocol to avoid that error:
<img src="https://mydomain.com/imges/picture.jpg" />
austin322980
I would understand why you get this issue with:
index.php
because of the Facebook and Twitter links but why get this error on:
products_search.php
which are all the urls are being writtin as HTTPS because of the .htacesss? Is there any where in the code that I can replace the http with https like a global.php file?
I dont get any errors when visiting your search page using Chrome, safari, Fire Fox or IE 9, 8 and 7
none of the browsers I have tested with are giving any errors when visiting your search page. I am not able to reproduce the problem.
austin322980
The desired end result is to get the bar in the URL similiar to when you to:
userprofile.php
When you go to:
www.crestviewsportinggoods.com
All three browsers (Chrome, IE 9, and Firefox) give the similar error of:
You have requested an encrypted page that contains some unencrypted information. Information that you see or enter on this page could easily be read by a third party.
I have completed the .htaccess code of this:
RewriteEngine On
Is there something else in the CMS that allows me to change the URLS so point to embed content?
when i visit that URL, I do not see any such errors.
maybe you have taken down the problem page?
I cant advise on the cause of the problem if i cant see the problem, all i can tell you is that that error happens if you have fully qualified URLS on the page that use the HTTP protocol.
