Sample pages?
Thread begun 5/24/2011 10:42 pm by AlaskaTom | Last modified 5/31/2011 10:10 am by Jason Byrnes | 2801 views | 4 replies |
AlaskaTomBeta Tester
Sample pages?
I am considering upgrading, and I have a couple questions.
Are there some sample pages created by SA2 available to view somewhere? I was disappointed by the bloated css structure, and the huge long class names etc created by form builder, and I wanted to see some pages generated by SA2 before buying. They dont need to be the full php code, but just the rendered html is fine.
Also is the forgot password email customizable? This was a problem in SA1. It would be nice to generate a nice html email, or at least a fully customizable text email, and have the ability to edit it.
Does the forgot password automatically send the login credentials to the user if the password is unencrypted, or encrypted with 2 way encryption?
And does it send a reset link (vs a temporary password) if the password is encrypted using an non decrypt-able method?
Thanks!
Tom
iansheldon422428
Hi Tom,
Having already upgraded I can confirm that the email format within the extensions own 'window' is the same as SA1, however there is now the option to select an external HTML file so that might get around your problem here.
I personally don't use the custom made forms that SA creates during the wizard, so I'm afraid I can't comment on that.
Cheers
Ian
here is a set of pages I created using the crypt encryption type.
Yes, the forgot email is customizable, by default a template file is created for the email, you can customize the template file layout.
With 2 way encryption types, the password is sent in the email, with the one way encryption types, a reset password page is used.
Jason,
Thank you for taking the time to do that.
Looks like a worthwhile upgrade, and I will be getting it.
Tom
no worries.
