Image access through built in editor
Thread begun 5/24/2011 5:36 am by david.cooke172080 | Last modified 5/25/2011 9:16 am by Daryl | 2186 views | 3 replies |
david.cooke172080
Recently installed version 4.5 on my server - when I attempt to access to insert an image and click on the browse server button I recieve permission error
"file permissions error has occurred. Please check the permissions on the script and the directory it is in and try again"
I know it should be a simple issue of changing permissions - but what directory are images accessed from and what is the permission setting required.
Note: Out data center for security prefers not to use 777 or 666 for scripts which is understandable.
the file manager uploads to the imagesupload folder, 755 should work for the permissions on that folder.
david.cooke172080
Reset permissions
After changing permissions to folder still reciewve the same error
'A file permissions error has occurred. Please check the permissions on the script and the directory it is in and try again.'
The url of the message window is
index.php?uicolor=%23eee&theme=webassist_v2&showsidebar=true&startup_folder=cms_files&CKEditor=ContentValue&CKEditorFuncNum=1&langCode=en-gb
DarylBeta Tester
I had to CHMOD all sub directories and files within kfm to 755 to get mine to work
