Radio Button options instead of select
Thread begun 5/23/2011 5:01 am by lee283140 | Last modified 5/23/2011 1:33 pm by Jason Byrnes | 3118 views | 5 replies |
lee283140
Is it possible to have radio options on the product detail page instead of select elements.
Ive tried changing them and modifying the relevant code so the radio buttons are within the loop where the options of the select element use to be but when i test it, it doesn't update the price etc like theres a problem with it referencing the options.
Could anyone post the correct code
any help would be great.
thanks
No, radio buttons are not supported in power store for product options.
lee283140
Radio Buttons
Can this not be acheived by modifying the add_to_cart.php page. for example;
<?php do { ?>
<input type="radio" name="ProductOptions_<?php echo($row_ProductOptions['OptionGroupID']); ?>" id="ProductOptions_<?php echo($row_ProductOptions['OptionGroupID']); ?>" value="<?php echo $row_OptionValues['OptionID']?>" <?php echo((strpos($row_GroupedOptions['ProductOptions'].",",$row_ProductOptions['OptionGroupName'].": ".$row_OptionValues['OptionName'].",")!==false)?"checked":""); ?> onChange="updateProduct(<?php echo $row_WADAProducts["ProductID"]; ?>,<?php echo($row_GroupingRS["GroupingID"]); ?>,'<?php echo($UsePath); ?>','<?php echo($WAGLOBAL_Images_Folder); ?>')"> <?php echo $row_OptionValues['OptionName']?><br />
} while ($row_OptionValues = mysql_fetch_assoc($OptionValues));
$rows = mysql_num_rows($OptionValues);
if($rows > 0) {
mysql_data_seek($OptionValues, 0);
$row_OptionValues = mysql_fetch_assoc($OptionValues);
yes, it _can_ be done by modifying the code. however, it is not a supported feature, meaning that if you are having trouble implementing it, we will not be able to offer much help.
lee283140
radio buttons
k thanks i understand.
Can you at least point me in the right direction on the code i need to implement.
ive tried the code in the previous post but it fails to update the price etc on change.
I haven't actually tried doing this, so i cant say what the code should be. if it is not updating the price, I would guess that there is a javascript error occurring, you should use Fire Fox / Fire Bug to track down the javascript error.
