Error Generating: buildFieldGroup
Thread begun 5/22/2011 7:35 pm by Larry321390 | Last modified 5/25/2011 2:14 pm by Jason Byrnes | 3586 views | 5 replies |
Larry321390
I get this message when I insert a form and push finish.
TyoeError: ShowIfObject.satPrams is not a function
then I have to use windows task manager to shut down dreamweaver cs4
Regards,
Larry
See the known Issues section of the form builder download center page for a fix to this issue.
elgueromero13396227
Jason,
Do you have a link? I can't seem to find this page nor can I find the webassist folder to change the .js file that was included with the download.
go to the download center page here:
downloadcenter.php
in the products list, click the link for CSS Form Builder 2 to go to the CSS form Builder download page.
In the Known Issues section, look for the link titled:
CSS Form Builder 2: Support Fix - A JavaScript error occurs when installing Form Toolkit after CSS Form Builder 2
the webassist folder is in the configuration folder. For help locating the configuration folder, see the common installation issues pdf:
once you locate the configuration folder go to :
configuration/shared/webassist
elgueromero13396227
Thanks That fixed this problem for me anyway.
you're welcome.
