can't upload image .bmp extension
I can't upload image with .bmp extension
Is there a setting in Helper that needs corrected
thanks for your help,
-Jim Balthrop
-Jim Balthrop
do you have the option for web images only set? BMP is not considered a web image format, the standard web image formats recognized by the W3C are:
png, jpeg, gif, svg and cgm
Yes,
i had web images only checked.
Probably not a problem, I doubt very few uploads would be .bmp format.
but i will uncheck web images only.
thanks Jason
