Login PowerCMS not working
Thread begun 5/20/2011 5:24 am by webwerkt | Last modified 11/15/2011 12:12 pm by lplatz167059 | 10181 views | 13 replies |
webwerkt
Login not working no more.
Power CMS, Site and database have worked in recent months.
I checkd the Database. the password and so on are okay, both SuperAdmin an User.
Both do not respond anny more.
users_login.php?accesscheck=%2FAcms%2Fadmin_cms%2Findex.php%3F
login
in the WA_SecurityAssist/Helper_PHP.php file, change line 4 - 6:
if (!isset($_SESSION)) {
    session_start();
@session_start();
webwerkt
Login problem
This has no effect.
Basically, nothing changed before or after the occurrence of the problem.
I can send you the login details!
the host may have updated the PHP install on the server and there is now a session management issue.
to test session management, use the session test page from the following post:
showpost.php?p=23826&postcount=2
if the session test fails, you will need to contact the host to have them correct the issue, most likely it is a problem with the session.save_path in the php.ini file.
webwerkt
login glitch
What happened. We had used the max bandwidth. And this was the effect. No message from the web host. But simply a blockade of all the uploading data without warning.
After upgrading our hosting package, everything went back to normal
ok, glad to hear it is now working again.
bericson407281
Same problem.
For no reason...login is not working. Nothing has been touched in weeks. You attempt to log-in and your credentials disappear. Nothing happens.
The following is not an issue:
session_start();
PHP Code:
@session_start();
It was correct in the file and did not need to be changed. Bandwidth is not an issue, it is unlimited. Also, the sessiontest was fine. The clients' website is hosted on BlueHost.
This needs to be fixed immediately.
bericson407281
Cancel that support ticket, I guess.
Just finished a conference call, tried to sign-in again and all is well...it works like it should.
Server hiccup???
pk, glad to hear it is working again.
