Account Access Subfolder
Thread begun 5/19/2011 10:40 am by johna1964 | Last modified 5/19/2011 11:30 am by Jason Byrnes | 3543 views | 6 replies |
johna1964
Can I place all of the Security Assist Wizard files and any other files associated with account access into a subfolder. If I can, do I run the wizard specifying the subfolder like so: /accountassess/usere_login.php?
I can specifiy the subfolder and file with CSS MW, but I need to know how to specify the file path for the wizard.
Thanks again!
johna1964
yes, that is correct, in the izard, you can specify the pages be crdated in a subfolder by adding the subfolder in front of the page names:
johna1964
Next Question Re: Subfolder
Jason,
Here's the problem I've run into:
When I run the wizard, and specify the files subfolder such as you verified, it will not allow the subfolder location. When I select the back button during the Wizard, it deletes the subfolder location from the file path and states there is no such file, and there isn't because the wizard hasn't created the pages yet. So, can I move the files to the subfolder after running the wizard and it automatically updates the file location?
Many Thanks!
Johna
johna1964
Step 1 of Security Assist Wizard
Jason,
What would happen if I specified the file location on the first step of the wizard in the pages section? Would it generate the pages in the subfolder?
Thanks!
Johna
yes, step one of the security assist wizard is where you specify the sub folder, in the pages section.
johna1964
Jason,
I'm sure this will make the difference...
Thanks!
Johna
you're welcome.
