IIS7 - Inserting an Image or File reveals the entire path!
Thread began 5/18/2011 4:14 pm by codamedia | Last modified 5/19/2011 12:36 pm by codamedia | 1174 views | 2 replies |
codamedia
In IIS 7, when I go to insert an image or a file from the file manager - it is listing the entire path of the file, not just the relative path.
EG: "D:/sites/domain/images/filename.xxx"
instead of "images/filename.xxx"
The problem does not appear with IIS 6, or the few different versions of Apache I have tested on.
Because of this, the references are wrong and require hand coding to remove all the extra data. This is not ideal for end users. I would really like to find a solution to this problem.
In another thread, we started a support ticket to investigate this issue, our engineering team should be contacting you shortly.
codamedia
Jason: I know you opened a support ticket (and I appreciate that), however this was actually a secondary problem to my initial problem.
Support helped me with the initial problem, but I have not heard anything about this IIS7 problem from them. Communications stopped in that support ticket as soon as my initial problem was corrected.
I created this thread in order to keep the two problems separated, and to emphasize that this has not yet been addressed.
