product thumbnail
Thread begun 5/18/2011 12:31 pm by cicyou421883 | Last modified 5/23/2011 2:03 pm by Jason Byrnes | 3706 views | 5 replies |
cicyou421883
product thumbnail
I cannot get my product thumbnail to show on the products_Detail page.
The images show, but not the thumbnail. Tutorial for images had to bind source. Please advise so the that the thumbnail will show on all pages when products_Insert is used.
Thanx, Cathy
anonymous
Did you double check to make sure that the path to your thumbnail is correct? Also, if you could, post your code here so that someone who may be able to help can get a look at it to see what is going on.
Best regards,
Brian
cicyou421883
Product Thumbnail in cart
Here is the code on cart.php. Path appears to be correct. Tried is with the current ../images and without the ../
while (!$californianatural->EOF()) {
<tr>
<td class="eC_GroupColumn"><a href="../products_Detail.php?<?php echo $californianatural->DisplayInfo("ID"); ?>="><img src="../images/<?php echo $californianatural->DisplayInfo("Thumbnail"); ?>" alt="Product thumbnail" class="eC_ProductThumb" /></a>
<p class="eC_ItemName"><?php echo $californianatural->DisplayInfo("Name"); ?></p>
<p class="eC_ItemDescription">Description:&nbsp;<?php echo $californianatural->DisplayInfo("FullDetails"); ?></p></td>
<td class="eC_PriceItem"><?php echo WA_eCart_DisplayMoney($californianatural, $californianatural->DisplayInfo("Price")); ?></td>
<td class="eC_FormItem"><input type="text" name="californianatural_Quantity_<?php echo $californianatural->DisplayIndex; ?>" size="3" value="<?php echo $californianatural->DisplayInfo("Quantity"); ?>" /></td>
<td class="eC_FormItem"><input type="checkbox" value="<?php echo $californianatural->DisplayInfo("ID"); ?>" name="californianatural_Delete_<?php echo $californianatural->DisplayIndex; ?>" /></td>
<td class="eC_PriceItem"><?php echo WA_eCart_DisplayMoney($californianatural, $californianatural->DisplayInfo("TotalPrice")); ?></td>
</tr>
Link to cart.php page is
cart.php
Add Hair to cart since that thumbnail is ready to go
Thanx, Cathy
looking at the source of your cart, the image src is being set to:
../images/images/hair75.jpg
<img src="../images/images/hair75.jpg" alt="Product thumbnail" class="eC_ProductThumb">
it looks like the add to cart button is already adding the path, the cart code should be:
<img src="<?php echo $californianatural->DisplayInfo("Thumbnail"); ?>" alt="Product thumbnail" class="eC_ProductThumb" />
cicyou421883
Fixed
Hey Jason - This worked - thanx for the infor and code. Cathy
you're welcome.
