[BUG] small issue
Thread began 5/18/2011 9:51 am by Steve | Last modified 5/20/2011 1:31 pm by Jason Byrnes | 943 views | 3 replies |
Steve
[BUG] small issue
Hello,
This bug has been confirm in my local environment by running a basic menu link that uses a dynamic population of titles and results.
Basically the "WA_dotDotSlash" function and subsequent relations are incorrect.
See attached screen shot that shows the working connection path stepping back two directories and the WA_dotDotSlash function not matching this same ../../ value.
This results in a PHP error as the path is not correct.
I have to manually make the change but the extension should be getting this right from the start. Maybe this bug is already logged?
Screen shot attached to show the extension generated result prior to manually fixing the path...
I am trying to reproduce a problem with this, but cannot.
Can you send a screen shot showing your sites files structure and a screen shot showing the site definition settings on the testing server tab.
Steve
emails sent to your account
