Combining Login and Registration Pages
Thread begun 5/18/2011 8:47 am by johna1964 | Last modified 5/18/2011 11:45 am by Jason Byrnes | 2796 views | 3 replies |
johna1964
Can I combine the login and registraition pages? If so, do I need to do anything special with the php code or can I place the code above or below the other?
Thanks!!
You can add the login form and registration form to the same page, make sure each form has a unique submit button name.
then in the Authenticate User behavior, make sure to set the trigger to use the Submit button from the login form, and make sure the insert record behavior uses the submit button from the registration form as the trigger.
johna1964
Jason,
That makes me happy!
Thanks again!
johna
you're welcome.
