WA Cookies Toolkit Question
Thread begun 5/17/2011 11:53 am by johna1964 | Last modified 5/17/2011 1:57 pm by Jason Byrnes | 2089 views | 3 replies |
johna1964
Server Behavior Panel>WA Toolkit>Set Session Value
After creating the new session variable to hold the new password
Instead of:
WA Set Session Value (NewPW)
I am seeing:
eCart Set Session Value (NewPW)
in the Server Behaviors Panel. The tutorial shows WA Set Session Value (NewPW). Since I have not implemented e-cart, I feel this is probably not correct. I deleted the eCart Session Value and repeated the process. It created the same result.
I also noticed Server Varibles in the Select the Value Dialog box that does not appear in the tutorial. Is this incorrect also?
Thanks!
johna1964
there is no problem, it is showing that way in the behaviors panel because you have eCart installed which also contains the Set session value behavior, that is only the label for the behavior, and will not effect the code that is generated on the page.
johna1964
What a relief!
Jason,
Your response time is impeccable...
Thank you!
you're welcome.
