PowerCMS Editor won't work.
Thread begun 5/17/2011 11:25 am by tkendrickmail32213 | Last modified 6/13/2012 7:35 am by Jason Byrnes | 6621 views | 15 replies |
tkendrickmail32213
The edit button will not bring up the editor any more. I cannot make edits to this website anymore (and cannot work in Dreamweaver either). I am dead in the water now and cannot work on this site any more. I applied the latest build from the beta (after removing currnet extension) and it won't work now. I can be called in the afternoon, EST. 803.746.7369.
thehermitvi425323
I am getting a similar problem.
Only the super admin can login and I keep getting redirected to the index.php even when I click on Settings. I can see some of the pages like individual content pages but when you click on edit you are redirected to the index.php in admin. This was working fine for about almost a month but something has changed. It is hosted on GoDaddy (not my choice) and I don't know if they changed something.
Another thing I just noticed is that it won't let me log out now.
mgorecki376668
Same Error Here
Edit was working but now just flashes. Am able to add new content. Settings page does not load also.
UPDATE: I Found the fix on a different thread
showthread.php?t=19439&page=2
lee283140
same problem
I have the same problem. did anyone solve it.
It seems to be something to do with the serial i think. because if i run the install process again it works. but then my other website that uses powerCMS then develops this problem. if i run the install on this the problem returns to the first powerCMS website.
Its as if the serial used can only run on one domain?
Any help would be great
lee283140
thanks
ive found the problem
cldsk369146
I just posted this same error
I just posted that I am now having this exact same problem...the above post with the fix to this error has a link that no longer works...I will be available via phone tomorrow from 11:00AM-3:00PM Pacific....would definitely appreciate a call/ticket on this.
Thank you!
~Chris
the link should go to this thread:
for most people having this sort of issue, the fix is to edit the WA_SecurityAssist/Helper_PHP.php file.
Change:
if (!isset($_SESSION)) {
    session_start();
@session_start();
