Shipping Pick Up Option
Thread begun 5/15/2011 12:56 pm by Maplemac | Last modified 5/18/2011 11:43 am by Jason Byrnes | 4762 views | 9 replies |
Maplemac
Hi
I have to add an option for the client to pick up the order so the shipping will be zero.
I have added a checkbox to checkout.php
to checkout:
<input type="checkbox" name="pickup" value="1" />
And a hidden to confirm.php
to confirm:
<input type="hidden" name="pickup" value="<?php echo isset($_POST[pickup]?$_POST[pickup]:""); ?>" />
When I try and add a session variable to the confrm.php it does not find the form element 'pickup'
What am I doing wrong or should I be doing this another way.
I was planning on setting a discount when session varible exists 'pickup'
www.perfectharmonybaskets.com
this code:
is not correct, it should be:
<input type="hidden" name="pickup" value="<?php echo isset($_POST['pickup']?$_POST['pickup']:""); ?>" />
also, make sure that the hidden form element code is inside of the form tag with the rest of the hidden form elements on the confirm page
Maplemac
Where exactly do I add the hidden form element code as there are no other hidden form elements on the confirm.php page.
I am using Powerstore 5 with ECart
If i add it to the form elements on process_transaction.php I get a page error when I click on Checkout.
what payment gat4eway are you using.
Maplemac
PP Standard
it should go in the webassist/plugins/shopping_cart/process_transaction.php file.
look for the following line:
<form name="checkout_PP_LI_Hid"  action="https://www.PayPal.com/cgi-bin/webscr" method="post">
and change it to:
<input type="hidden" name="pickup" value="<?php echo isset($_POST['pickup'])?$_POST['pickup']:""?>" />
Maplemac
As soon as I make those changes to the process_transaction.php and add the server behaviour I get a HTTP500 error once clickig on checkout.
I have attached the process_transaction.php file
use this code:
Maplemac
Thanks and hopefully final question.
How to set the discount if the pickup checkbox is checked and the two towns that get free delivery are not in the shipping address.
Using if session variable = pickup with value of 1 is not picking up the discount.
Do I need more details.
