just can't get this to work....
Thread begun 5/15/2011 3:16 am by Sn0man | Last modified 5/16/2011 3:36 pm by Jason Byrnes | 7726 views | 24 replies |
Sn0man
So i've built and deleted all ecart pages, recordsets etc 4 times now, and each time I have the same problem - I can't get past the cart.php page, as I just keep getting redirected back to it.
I've made the recordset with all the correct bindings, and the correct information shows up on the cart.php page. I've uploaded the two tables to my server (orders.sql and orderdetails.sql). I'm using the userID from the users table, and added two additional columns; one for item description and one for amount. Then created the recordset with those three columns and the test displayed the data correctly.
I'm not sure what i'm missing here, but this just doesn't want to work for me! Also, each of the 4 times i've run the checkout wizard, I have not had a window for universal email reciept - even though I have universal email installed and working correctly.
Anyhow, here is the code from my success page (which has the add to cart button), and the code from the cart.php page.
Thanks for any help - i'm running out of hair to pull out!! ;)
admin140217
I may have missed this...
I may have missed this in looking at you code but...
When you added your add to cart button to the page, did you designate a URL in the general tab "redirect" section of the add to cart button panel?
Sn0man
Thanks for the reply -
Yes, on the success page which has the add to cart button, I have set it to redirect to cart.php, and on the cart.php page which has the checkout button, I have set it to redirect to checkout.php. However no matter what I try, when I press checkout, it just takes me right back to cart.php (almost like it wants to go to the next page but gets redirected back instead).
Sn0man
That makes 5 times
This time I removed the extension, and all ecart files and folders and generated pages, and re-installed, then went through all the steps, again...
still getting redirected back to the cart page and still no option to send a reciept with Universal Email.
Found this code snippet in the confirm.php page
if ($eCart1->IsEmpty()) {
$eCart1->redirStr = "cart.php";
$eCart1->cartAction = "RedirectIfEmpty";
Which, I can only assume, means that for some stupid reason the information isn't being written into the database.
Sn0man
Still nada
Well i've managed to get the data to write into the database using the "store summary in database" server behaviour (not to be found anywhere in documentation), but still not getting past the cart.php page - always ALWAYS redirects back to itself.
This is the eighth attempt and everything else seems to be working - it just won't complete the transaction.
Here are screenshots from my PC showing the server behaviours in play on the cart.php page, a screenshot of the mySQL database after data was written to it, and the complete code from my cart.php page.
I'm giving up on this extension until I can get some help -this just doesn't want to work for me at all.
When you run the checkout wizard, what payment gateway are you selecting?
Can you send a link where i can see the problem?
It could be that a php error is occurring, add the following code to your pages to turn error reporting on:
error_reporting
(E_ALL);
Sn0man
error_reporting
(E_ALL);
Hi Jason,
I'll PM you a link and login info as I have this set up on my sites back-end.
For the payment gateway, I selected paypal website payments standard, and entered the correct business credentials (secure merchant account ID) from my paypal profile page.
I assume I should add that code to line 1?
Sn0man
I guess I can't PM you.
login here users_login.php
username: jason@webassist.com
password: temp
i've set up a test amount of $0.01 owing so you can see what's happening.
did you add the error reporting code:
error_reporting
(E_ALL);
at line 1 of the checkout.php file?
Sn0man
just did it
