Blank Page
Thread begun 5/13/2011 12:35 pm by fabrizioripesi426077 | Last modified 5/17/2011 12:05 pm by Jason Byrnes | 6495 views | 9 replies |
Blank Page
My test page for Pro Maps for Google doesn't work : google.asp .
I have uploaded the folder Google javascript and promaps cache
I have made e regular connection with database access, AspVb, but all is blank!
Can you help me?
Fabrizio
send a copy of the google.asp page please
Google.asp
Hi, as you required I attached the page google.asp
I crated a recordset and hten I have applied the extension.
Thanks!
in the google.asp page, find the following:
Recordset1_cmd.ActiveConnection = MM_bbroma2011_STRING
and change it to:
MM_bbroma2011_STRING.CursorLocation=adUseClient
It doesn't work:
Microsoft VBScript runtime error '800a01a8'
Object required: 'DRIVER={Microsoft Ac'
/Bed-and-breakfast-Roma/google.asp, line 16
send the latest copy of your page.
Google.asp
Here the file
ok instead of:
try using:
Recordset1_cmd..CursorLocation=3
google.asp
NOthing.
If I realize a map with a single address is ok, but of I put a recordset...the page is blank.
In the code generated there are the records, but the map is not visible.
I use asp + access, and Dw Cs4
Can you help me?
Have I to set other besides the extension?
