Displaying Price Range Options
Thread begun 5/13/2011 3:10 am by A Sound Design | Last modified 5/20/2011 10:48 am by Jason Byrnes | 8316 views | 29 replies |
A Sound Design
On my page I am trying to create a list of values that a customer can choose between so that they can filter records from the Recordset based upon a price range such as:
Up to £500
Up to £700
Up to £900
Up to £1500
Up to £2500
I can get this to work using the SQL statement
SELECT * FROM content WHERE Price > 0 AND Price < 500
This works fine but I'm sure there's a better way of doing it rather than creating 5 different recordsets, one for each price range.
create a select list that passes the price as the value, for example:
<select name="maxPrice" id="maxPrice">
<option value="500">Up to 500</option>
<option value="700">Up to 700</option>
etc...
</select>
the forms method should be set to post.
then in the recordset go to advanced view, set the SQL as:
SELECT * FROM content WHERE Price > 0 AND Price < paramMaxPrice
Next, create a parameter:
Type: Number
Default value: -1
Run Time value: $_POST['maxPrice']
A Sound Design
Type: Number
Default value: -1
I've got a bit lost at this point. Where do I create the parameter? Is it linked to what happens once the 'Search' button is pressed on the select list form?
you create the parameter in the parameter section of the advanced recordset view.
A Sound Design
Thanks. I was confused by you using the term parameter. In Dreamweaver CS4 it is 'Variable'.
Not quite sure what this is supposed to be showing as I have created the recordset and form but when I click Search it does not return anything. I've been at this for hours so maybe I'm just a bit tired. Should it be posting to a separate page? The Action of the form is blank at the moment. I was hoping that it would just filter the records on the page and show only those that are in each price range. Is that what it is supposed to do?
Thanks for your help so far.
Not sure when they changed that, It used to be parameter, sorry for the confusion.
send a copy of your page please.
A Sound Design
Zip of page attached. Btw, is it safe to put code of a whole page up here? Technically anyone could download it. Am I correct? Just don't want to make my site vulnerable.
I'm a little confused, you applied the filtering to the rsPrice recordset, but you are not using that recordset anywhere on the page?
the only recordset that is used on the page is the rsOffers recordset?
A Sound Design
Well, I created the rsPrice recordset to create the filter for the Search By Price select list that you have been helping me with in this thread. I thougt this would then be displayed by the output of the maxPrice form
<form id="frmPriceRange" name="frmPriceRange" method="post" action="">
<label>maxPrice
<option value="500">Up to £500</option>
<option value="700">Up to £700</option>
</select>
</label>
<label>
<input type="submit" name="button" id="button" value="Submit" />
</label>
</form>
The rsOffers is to simply display all records from the DB.
Please advise me as to what I need to do now to get it working.
So then it is the rsOffer recordset you want to apply the filtering to.
add the variable to filter by price to the rsOffer recordset.
