Pull data from MySQL to display in table
Thread begun 5/12/2011 5:50 pm by Sn0man | Last modified 5/16/2011 8:11 am by Jason Byrnes | 2904 views | 4 replies |
Sn0man
Hello again!
What i'm trying to do is to pull 5 feilds from my users table to display on my admin_index page, which will contain clients hosting, password and domain expiry information. I created a recordset that contains all these fields, then got stuck trying to figure out what the next steps would be.
I'm pretty sure I know how to get these things to display on the users_Profile page using session variables, but i'm nor sure how to get them to display on my admin_index page. I had a look at the results page to see what the code was doing to display all those records, but I couldn't quite get a grasp on what i'd need to do to make it work.
Any help?
Thanks in advance :)
create a table with 1 row and 5 columns.
Open the bindings panel, and expand the recordset binding group.
Drag the binding for each recordset column into the a cell of the table.
In the tag inspector, select the tr tag, then go to the server behavior panel and click the plus button. Select repeat region to add a repeat region around the table row to loop through the recordset and create a new table row for each result.
Sn0man
Thanks Jason,
I did all those steps, but the data still isn't appearing?
Sn0man
Nevermind, I figured it out. I just had my recordset configured incorrectly. Thanks!
Ok, glad to hear it is working.
