Add To Cart - reposts to self with no product info
Thread begun 5/12/2011 12:28 pm by jswaringen | Last modified 8/21/2013 1:10 pm by Patrice | 6214 views | 12 replies |
jswaringen
I have a strange problem. I have a page that is set to post the shopping cart view ("cart.php") however whenever I add it to the cart it reposts to itself, and there is no product information on the page. If I post again it's added to the cart properly. Any suggestions on how to troubleshoot this would be appreciated.
The page can be seen at:
products_Detail.php?ProductID=26
And the code is attached.
mve this code form line 10 - 15:
// WA eCart Redirect
if ($htcCart->redirStr != "")     {
header("Location: ".$htcCart->redirStr);
to be just before the doctype tag.
jswaringen
I did this and still no change. I'm thinking that somewhere in this code is where the error is, but it seems to match up with everything above it:
if ($ATC_RedirectAfter != "" && $htcCart->redirStr == "")     {
      $htcCart->redirStr = $ATC_RedirectAfter;
    if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "")  {
      $_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
    else  {
      $_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
try changing:
session_commit();
jswaringen
For some reason the "redirStr" property is never being set. I used Firebug/FirePHP and it always shows up empty.
change:
$row_WADAproducts = WAEC_findRecordMySQL($WADAproducts, "", $ATC_itemID);
$row_WADAproducts = WAEC_findRecordMySQL($WADAproducts, "ProductID", $ATC_itemID);
jswaringen
That fixed it, thanks for the help.
You're welcome.
PatriceWebAssist
I tried a couple of these suggestions on current install of ecart but wasn't successful. If you get a minute can you look at this please?
http://wyoming-county-health.org/donationsTEST.php
just looking at the code you posted i can see 2 problems:
1) the add to cart code needs to come after the code for the recordsets
2) you have blank lines between php code blocks that will cause the redirect to fail.
