Captcha Not Case Sensitive
Thread begun 5/12/2011 10:45 am by A Sound Design | Last modified 5/12/2011 12:58 pm by Jason Byrnes | 3358 views | 5 replies |
A Sound Design
I have a Captcha on the form which works except for the fact that if it throws up, for example C6Tui, it will also except c6tui. In other words, it doesn't make any difference if you follow the case of the letters as long as you type the correct letters.
In the list of server behaviors, double click the Server Validation server behavior.
From the list of validations, select the Like Entry validation and click edit.
In the Like entry validation settings, check the uncheck the Not Case Sensitive option.
A Sound Design
From the form that I created with Form Builder there is no Server Validation to double click. Should this have been created automatically when the form was created?
The server validation server behavior should be in the server behaviors panel. it is the code that makes the captcha work, if it is not there, captcha would allow any string to be entered.
Send a copy of the page please.
A Sound Design
The attached page was created using Security Assist and Form Builder
