Data only going to first assigned email address
Thread begun 5/12/2011 10:43 am by wrigd | Last modified 5/16/2011 8:41 am by Jason Byrnes | 4740 views | 8 replies |
wrigd
I have set up UE4 on my site to send out results information to subscribed members. The body of the email contains recordset data and the email addresses are set up to send via 'Once per entry' on a 'recordset loop' from my member email database table.
The problem I am having is that the emails get sent out but the recordset data that is in the body of the email is only being sent to (only appears on) the first email address as assigned in my recordset for the members email addresses. If I change the sort order of the members emails recordset then the first one listed is the only one that will receive the information in the body of the email. The rest of the email addresses receive the email but no body information. Any help would be appreciated. Thanks.
See the following thread for details:
showthread.php?t=17869
wrigd
Hi thanks for the reply. Sorry if I am being a bit dim but where am I to apply this code to exactly and which column name am I too apply (the email addresses column or the results column?).
I am not using one of the assigned templates in UE4 and have created the file to be emailed in Dreamweaver (clicking the Dreamweaver icon in the UE4 wizard). Many thanks.
In the webassist/email/templates folder is the template file for your email
add this code at line 1 of that file:
global $RecipArray;
global $RecipIndex;
then replace each instance of the code that references your recordset:
<?php echo $row_RecordsetName['yourColumnName']; ?>
with:
<?php echo($RecipArray[$RecipIndex][0]["yourColumnName"]); ?>
where "RecordsetName" is the name of your recordset and "yourColumnName" is the name of the recordset column.
wrigd
Hi Jason,
Many thanks for your help. I now have the emails working perfectly. Thanks again.
wrigd
Hi, I have just one other question. I have applied the UE Progress Bar to my submit form but I have multiple buttons that send out different emails (4 submit buttons in the same form all using different templates). The progress bar only seems to be working on one button.
When adding the progress bar I am only able to apply one and any attempt to insert a new Progress Bar, via the wizard, overwrites the last one applied. The bar will show up when any of the other three buttons are pressed but just no indication of progress. Is there a way to have the bar working on all 4 buttons in the same form? Many thanks.
No, the progress bar cannot be applied to a form with multiple submit buttons.
wrigd
Ok thanks. So I would need to apply each button to a seperate form then. Many thanks again for your help.
yes, that is correct.
