Validating Checkbox Group
Thread begun 5/11/2011 10:36 am by solasweb104077 | Last modified 5/18/2011 7:26 am by Jason Byrnes | 3430 views | 5 replies |
solasweb104077
Hi, is it possible to add client validation to a group of checkboxes all with the same name but with different values so that the user has to select at least one of them?
See the file attached that was created by adding a checkbox group in DW
Yes, you can use Required validation on the check box group.
solasweb104077
Thanks Jason I tried that but it only seems to be processing the form if the first checkbox of the group is ticked
I have attached the updated page
change the following line:
if (formElement.length && inputType.toLowerCase()!="radio" && inputType.toLowerCase()!="select") formElement=formElement[0];
if (formElement.length && inputType.toLowerCase()!="radio" && inputType.toLowerCase()!="select" && inputType.toLowerCase()!="checkbox") formElement=formElement[0];
solasweb104077
Thanks that works great
you're welcome.
