fatal error
Thread begun 5/11/2011 5:57 am by randyw2394710 | Last modified 5/12/2011 6:24 am by Jason Byrnes | 2283 views | 3 replies |
randyw2394710
fatal error
i installed powermailer in origanal format everything worked fine.
i have moved the folders put it inside admin costumerInfo and called the powermailer folder ManageCostumers in dreamweaver so it fixed every folder with that name
it installed fine now i get this message
Fatal error: Call to undefined function WA_getCMSContent() in /home/va010021/public_html/multiinnovations/admin/costumerInfo/webassist/themes/Default/templates/index.dwt.php on line 51
the login section works for the costumer section
This is a problem caused by moving the files in Dreamweaver after the installation.you should delete all of the power mailer files and install them to the folder you want them in, once installed, do not move them in Dreamweaver.
randyw2394710
I deleted all the files on the server. I deleted all the files on my computer. I then unzipped the original files, named PowerMessenger Files, CostumerInfo inside Dreamweaver. So the files changed site wide. I also changed the admin_pm to ManageCostumers, again Dreamweaver changed files site wide.
I then uploaded the new files. I completed the setup, the first problem, it did not create the connection file and install text, all the folders are 07777 execute all. So I did it my self, i was able to go through the steps to install. I was able to go to the profile area, in CostumerInfo, but the admin_pm which i named ManageCostumers does not work I get this error.
ManageCostumers/
Fatal error: Call to undefined function WA_getCMSContent() in /home/va010021/public_html/multiinnovations/admin/CostumerInfo/webassist/themes/Default/templates/index.dwt.php on line 51
