Dreamweaver Logout does not log user out!
Thread begun 5/11/2011 4:26 am by A Sound Design | Last modified 5/11/2011 7:52 am by Jason Byrnes | 4272 views | 1 replies |
A Sound Design
I am using the Dreamweaver Log Out User server behaviour but have noticed that when I test it by logging out it redirects to the logged out page I have but if I try the original page I was supposed to be logged out of I can still access that page, ie. I'm not really logged out.
Code:
//initialize the session
if (!isset($_SESSION)) {
session_start();
// ** Logout the current user. **
$logoutAction = $_SERVER['PHP_SELF']."?doLogout=true";
if ((isset($_SERVER['QUERY_STRING'])) && ($_SERVER['QUERY_STRING'] != "")){
$logoutAction .="&". htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_GET['doLogout'])) &&($_GET['doLogout']=="true")){
//to fully log out a visitor we need to clear the session varialbles
$_SESSION['MM_Username'] = NULL;
$_SESSION['MM_UserGroup'] = NULL;
$_SESSION['PrevUrl'] = NULL;
unset($_SESSION['MM_Username']);
unset($_SESSION['MM_UserGroup']);
unset($_SESSION['PrevUrl']);
$logoutGoTo = "logged_out.php";
if ($logoutGoTo) {
header("Location: $logoutGoTo");
exit;
If you are using security assist for login, the Dreamweaver Logout User behavior will not work.
Instead, Use the Clear Session Variable behavior from Cookies Toolkit (This is why cookies toolkit is included with Security Assist)
Set the Trigger to before page load, and set it to clear all session variables.
