Quick Cart Link doesn't work on FireFox4
Thread begun 5/11/2011 1:37 am by rikaG_510 | Last modified 5/13/2011 6:39 am by Jason Byrnes | 3496 views | 5 replies |
rikaG_510
My shopping site has a quick cart link button with a label called "View order".
This button works fine on Google Chrome, Safari, IE, but not on FireFox4.
It worked fine on Firefox3, now I have no clue what the problem is.
I tried adding the code of;
error_reporting(E_ALL);
from line 1, but nothing comes up when tested. So I guess there's nothing wrong with PHP (I mean, with other browsers everything works correctly anyway.)
Maybe it's some kind of CSS conflicts?
Could you help me finding out what the problem is and tell me what I can do to fix this?
Just in case I copied the code for the quick cart link button area.
If you need more source, please let me know.
Thank you for your help,
Rika
<div class="eC_Simple_Slate_Verdana eC_Simple_Slate_Verdana_QuickCart">
<form action="<?php echo ($_SERVER["PHP_SELF"].(isset($_SERVER["QUERY_STRING"])?"?".htmlentities($_SERVER["QUERY_STRING"]):""));?>" method="post">
<table width="124%" border="0" cellpadding="0" cellspacing="0" class="right_cart">
<tr>
<td class="eC_QuickCartLabel">
<img class="bag" src="rowing_images/bag.png" width="14" height="18" />
<a href="shop_cart.php"><input name="Swift_View_100" type="submit" id="Swift_View_100" onclick="MM_goToURL('plugins/parent','');" value="View order" /></a>
&nbsp;( <?php echo $Swift->TotalColumn("Quantity"); ?>&nbsp;items&nbsp;)&nbsp;&nbsp;|&nbsp;Total:&nbsp;<?php echo WA_eCart_DisplayMoney($Swift, $Swift->GrandTotal()); ?>&nbsp;&nbsp;</td>
</tr>
</table>
</form>
</div>
Please compress the php page into a zip archive and attach the zip file to this thread so I can see the code in context, also, it would be very helpful to have a link so I can see the problem happen in the browser.
rikaG_510
Hi Jason,
Thank you for your reply.
Here is the link for the site;
shop_01_rig.php
(This is just one of many pages with the same problem - please make sure you test it on FireFox4.01 - the latest one. There should be a button right above the product list saying "view order", which is the link not working.)
I've attached the PHP file for this page.
Looking forward to hearing from you!
Thanks,
Rika
you need to edit the View Cart button to tell it to go to the cart page.
First, open the Behaviors Panel, go to Window -> Behaviors (NOTE: dont confuse the behaviors panel with the server behaviors panel)
In design view, select the View Cart button, in the behaviors panel, double click the Go To URL Behavior to edit it and set it to go to the cart display page.
rikaG_510
Hi Jason,
Thank you!! I tried as you suggested and now it's working perfectly.
I'm so happy now... thank you.
Rika
Glad to hear it is working.
