Problems Adding Editor to Form
Thread begun 5/10/2011 7:14 am by A Sound Design | Last modified 5/12/2011 10:39 am by Jason Byrnes | 4105 views | 7 replies |
A Sound Design
I am trying to add HTML Editor to a form created with Form Builder. Every time I do this I get the error in the attached screenshot and cannot proceed any further.
What version of form builder do you have installed? And what version of HTML Editor?
A Sound Design
HTML Editor 3.0.1 and Form Builder 2.0.1
did you install Form Builder 2.0.1 before installing HTML Editor 3.0.1?
Form builder needs to be installed before installing HTML Editor. try uninstalling both, then Uninstalling FB 2.0.1 followed by HTML Editor 3.0.1 then delete the Dreamweaver cache file:
A Sound Design
Thanks Jason, as it now works ok by doing that.
But now I have the following error when I test my form:
Parse error: syntax error, unexpected '@' in C:\xampp\htdocs\***\****\add_an_offer.php on line 357
Code at lines 355 - 359 is;
<span>
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_@@ObjectNumber@@ = CreateRichTextEditor ("IntroText", "../webassist/ckeditor/", "@@Width@@", "@@Height@@", "@@ToolbarSet@@", "@@CustomConfig@@", "");
</span>
A Sound Design
The Parse Error seems to have been sorted out now. It caused this error when I tried to add HTML Editor to a Textarea in an existing form created with CSS Form Builder. When I went back into FB and added the HTML Editor from FB itself it works fine.
Ok, Glad to hear it is working.
