Creating new user/message notifications on admin page
Thread begun 5/10/2011 5:16 am by Jenny I | Last modified 6/20/2011 1:25 pm by Jenny I | 4449 views | 12 replies |
Jenny I
I have created a website that allows users to register and send comments using a contact form.
I have also configured my admin pages using data assist and security assist.
I just wondered if there was any way I could display a notification in my admin if a new user registers.
When I click on the notification I would then be taken to my user results table. On the results table beside each new user name I would like to display some text that says "new". If the admin clicks on the user to go to the detail page I would like that text to dissapear.
What I am trying to achieve is similar to how email notifications work on e.g. iphone. You get that red notification telling you how may new emails you have recived and when you open the email app that notification goes away.
Your help is much appreciated
CraigRBeta Tester
There are probably several ways to do this.
You could try adding a field to the registration table, with a boolean or tinyint data type, and set it to 0 by default.
on your results page, if the field value is 0, then you have a new registration, so you could highlight it in some way
when you view the registration record, you could apply an update behavior to set the value to 1
Jenny I
Thanks Craig,
I never thought of that I will give that a try now. I think your solution would definately solve my second problem but I am not sure how I would go about solving the first issue.
Basically when an admin logins in they will be taken to the admin homepage. On the homepage there will be a image link. I would like a little red alert image to display beside this everytime a new user registers. So if five user registers since the last time the admin clicked the image link the little red alert image will display "5". If admin clicks the image the alert disapears.
CraigRBeta Tester
you could add a recordset to the admin page based on the registration table, filtered where the new field value = 0
you could display the totalrows of this recordset as your alert.
You could also use this as a trigger to update the recordset and set the value to 1
Jenny I
Hi Craig
I am just working on your solution now I will let you know how I go.
Jenny I
Hi Craig,
Whwn I use DW total records behaviour it seems to ignore the filter I set in my recordset. It just counts all records in the table. I have tested my recordset and the filter definately works. This is the code DW puts out.
<?php echo $totalRows_RsUsers ?>
Do I need to add some additional code to get this to work?
Your help is much appreciated.
CraigRBeta Tester
<?php echo $totalRows_RsUsers ?> should show the correct number of rows returned from the recordset.
Are you sure your recordset is filtered correctly ?
can you upload your page as a zip ?
Jenny I
sorry there was an error on my page it is working now, I just need to update my results page.
Many Thanks
Jenny I
Hi Craig
So far I have manged to everything working but the update record behaviour. I applied an update record behaviour to my page to update the value of the column to 1 but it does not seem to work.
I think the problem is the trigger. I am not sure what to set it to as there is no form element on my detail page. I have tried using the recordset not empty but that does not work.
CraigRBeta Tester
