Edit Design Error
Thread begun 5/09/2011 9:30 am by badgerburrow415650 | Last modified 5/12/2011 6:50 am by Jason Byrnes | 2774 views | 4 replies |
badgerburrow415650
Edit Design Error
Hey guys, I have got a major problem with Powerstore 4.5
The program will not let me edit the designs, this has just occured within the last two days.
I am not entirely sure how it happened, but it did this: URL information has been editted out:
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in //webassist/plugins/styler/styler.php on line 99
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in //webassist/plugins/styler/styler.php on line 100
Warning: fread(): supplied argument is not a valid stream resource in //webassist/plugins/styler/styler.php on line 100
Warning: fclose(): supplied argument is not a valid stream resource in //webassist/plugins/styler/styler.php on line 101
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in //webassist/plugins/styler/styler.php on line 104
Fatal error: Call to a member function asXML() on a non-object in //webassist/plugins/styler/styler.php on line 117
The effect is that, I lost an entire website before I could back it up. The elements are still there and usable but I can no longer edit the designs, in the process all the permissions were changed and it disconnected your the sql. most of which I have corrected, Oh ya, and there is the little annoying problem of it not talking to the server, I keep getting a message that states that "there was an error in communication with the server".
Can you help me fix this?
regards
Badgermedicine
badgerburrow415650
addendum
More details: After looking around to see if others are having problems like mine, I see that they are.
I can neither browse the server and or upload graphics directly, it wouldn't let me change the design graphics without fooling the program into it, by directly downloading the graphics altering them in Photoshop and then uploading them again, even then, while most graphics were accepted the logo graphic would not work. Often graphics work in test mode but not in live mode. sometimes calling for placement of the graphics in identical folds outside the subdicrectory.
Then there was the flash issue: In order to get flash to work, I had to place the files both inside the directory and outside of it.
picky litttle program that it is.
Badgermedicine
stephen.woodward425543
Can't edit themes any more
Hi guys,
at first it worked ok but now i get an error editing themes it seems like the root files are missing. Could you take a look please?
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET4.0C; .NET4.0E; MS-RTC LM 8; AskTbNRO2/5.11.3.15590)
Timestamp: Thu, 12 May 2011 11:18:24 UTC
Message: 'Class' is undefined
Line: 15
Char: 1
Code: 0
URI: mooRainbow.js
Message: Object doesn't support this property or method
Line: 184
Char: 1
Code: 0
URI: design_settings.php?Editing=Shop
