Basic Contact form as plugin
Thread begun 5/09/2011 7:34 am by MikeH | Last modified 5/10/2011 9:50 am by Jason Byrnes | 4027 views | 9 replies |
MikeH
Hi
I have created a blank PHP page and added a simple contact form to it.
I have then used a statci plugin to insert the form page into another page.
Now I know about redirecting the form to the page that the form is plgged into not the actual form page.
Problem seems to be that if the server validation fails you are returned to the page but the form is blank again and needs filling out still.
Any solution to do this correctly?
thanks
Mike
for each form element on the form, click the lightning bolt next to initial value and select the corresponding item from the Validated entries binding group.
MikeH
Hi Jason
They are all set already.
Please find attached the page with the form. This is then plugged in to a page called contactus.php (outside the plugin directory)
Mike
please post a link where i can see the problem and a copy of the contactus.php page.
MikeH
Yep sure
<link removed>
Jason can you please remove th link as soon as you have it thanks..
Mike
you have form validation on the contactus.php page at line 5 - 24:
if (isset($_POST["SimpleContact_submit_x"]) && !isset($_GET["invalid"])) {
$WAFV_Redirect = "addins/contactform1.php";
$_SESSION['WAVT_contactus_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ((isset($_POST["Full_Name"])?$_POST["Full_Name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateEM((isset($_POST["Email_Address"])?$_POST["Email_Address"]:"") . "",true,2);
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Code"])?$_POST["Security_Code"]:"")) . "",((isset($_SESSION["captcha_Security_Code"]))?strtolower($_SESSION["captcha_Security_Code"]):"") . "",true,3);
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Answer"])?$_POST["Security_Answer"]:"")) . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,4);
$WAFV_Errors .= WAValidateRX((isset($_POST["Hidden_Field"])?$_POST["Hidden_Field"]:"") . "","/.*/",false,5);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"contactus");
this validation should not be on both the contact page and the addins/contactform1.php
this line is causing the problem:
it should be:
$WAFV_Redirect = "";
MikeH
Hi
Removed the lines from contactus.php I honestly do not know how they got there as I have never added validation to that page.
Now when the page is submitted it cannot reload the page you get an error saying page is unavailable so you refresh and the page loads with a blank form and the verification showing there had been a mistake during validation.
Oh and despite the failed validation the emails are still sent out.
Any ideas?
Mike
your contact us page also has a universal email behavior on it that should not be there.
MikeH
Hi Jason
This jas got me I never put anything on that page and when I removed the plugin from the page the Universal email and validations removed too.
Ive re-added it but still no luck when you submit the form it will not load.
Mike
