writing to the ecart database
Thread begun 5/07/2011 5:45 am by admin140217 | Last modified 5/09/2011 1:05 pm by Jason Byrnes | 5019 views | 5 replies |
admin140217
Okay, I'm probably just being stupid but I have set up a simple registration form using ecart 5 and can populate the form via the database, that works fine but I want to be able to write to the database for each registration made.
I don't work with databases that much but have done this before and have forgotten how.
Can someone point me in the right direction to start writing to the database instead of posting to it?
Thanks,
admin140217
Working on it
I still haven't been able to figure out how to write the form info into a database when submitting the form. maybe I'm going about it wrong but I would normally do this to write to a database, this code is working right now as an action page locally:
$con = mysql_connect("localhost","root","root");
if (!$con)
die('Could not connect: ' . mysql_error());
mysql_select_db("registration_db", $con);
$sql="INSERT INTO registrants (FirstName, LastName, City, State, Zip, Address, Address2, Phone, Email, Function)
VALUES('$_POST[FirstName]','$_POST[LastName]','$_POST[City]','$_POST[State]','$_POST[Zip]','$_POST[Address]','$_POST[Address2]','$_POST[Phone]','$_POST[Email]','$_POST[Function]')";
if (!mysql_query($sql,$con))
die('Error: ' . mysql_error());
echo "1 record added";
mysql_close($con)
In the generated ecart form the action is already assigned using a PHP_SELF statement.
What I want to do is have the information write to the database but also continue on to the shopping cart display for confirmation, then to PayPal for payment.
so I guess I'm saying that the problem isn't writing to the database but integrating the above action into the ecart generated files.
Use the eCart checkout wizard to create the checkout pages for you.
as long as you have a database connection configured before running the wizard, you will be able to configure the checkout pages to store the order information to the database within the wizard.
admin140217
Thanks Jason,
I think I was confused between the ecart object's add to cart function and checkout pages. I'll give it a try and see what happens.
admin140217
It is writing to the database but
Okay, I see where it is writing to the database now in the orderdetails table. If I modify that table to include other fields will this automatically be generated when creating the checkout system? Or will I have to add the fields I want written to in the confirm.php page?
If you add new fields you will need to edit the store order details server behavior to bind the new fields to the values.
