Refitting the Admin
Thread began 5/06/2011 4:49 pm by Brad Lawryk | Last modified 5/09/2011 10:44 am by Jason Byrnes | 905 views | 1 replies |
Brad Lawryk
Refitting the Admin
Hey guys,
Just bought this even though I am not sure I will be able to use it yet. I use CSS Sculptor for many sites and I use Data Assist for backends. Is it possible to integrate the Power Messenger Admin into my existing backend in both looks and authentication?
Or would my admin user have to log in twice, once in the back end and then again in the power messenger?
What about the looks can it be matched to the back end I built with other web assist products?
Brad
The Power Messenger admin pages use Themes from Framework Builder. You could create a framework builder theme from your css sculptor design to apply that design to the admin.
Just make sure the template you create from the css sculptor design has the same editable regions.
The admin login relies on a session variable AdminLogin having the same value as the admin login you set during the install.
in your regular admin login page, edit the authenticate user server behavior, on the third step, click the lightning and select the password column to store it in a session. Name the session AdminLogin
