Using a checked checkbox to update a user record
Thread began 5/05/2011 3:51 pm by Paul | Last modified 5/11/2011 11:55 am by Jason Byrnes | 1412 views | 4 replies |
PaulBeta Tester
I have a repeat selection table, 2-cols across, that populates with image thumbnails.
I am using Update and Delete multiple records to enable users to select and remove any image record or update it so it displays.
I'd like to add a 1 to my img count field (in the user table) for every image that is checked for deletion.
I'm following your thinking thru from an earlier post by using update server behaviour, but cant work out how it should only trigger if one or more check boxes are selected.
Any ideas?
Paul.
send a copy of your page so I can take a look at the code please, I'll see what I can come up with from that.
PaulBeta Tester
Its a challenge!
File attached.
manage-photos.zip
PaulBeta Tester
Jason,
I hope i'm not too late here!
I've managed to resolve, so you can drop this one.
Thankyou Paul.
Ok, Glad to hear you figured it out, Can you share the solution?
