Shipping address sames with select menu
Thread begun 5/05/2011 6:56 am by robert254422 | Last modified 5/05/2011 7:50 am by Jason Byrnes | 1978 views | 3 replies |
robert254422
Hello,
I would like to know the following...
When - on the checkout page in ecart - I select the shipping address same as billing address option all the fields for shipping get filled nicely except for country field.
The country field I use is a select menu (for billing aswell as send address)... What can I do/add/change to get the country value of billing address copied to the select menu for shipping_country in the send address part?
I hope my question is formulated clearly and I hope to hear from you.
WKR
Please post a link
robert254422
I was just posting the answer to this - TYVM!
I found another post on the forum about someone wanting to add extra fields..
The answer there was regarding the number of fields in the array need to be the same...
In my case I deleted some elements from both arrays that I do not use in the checkout form... After doing this the value of country in the select menu also gets copied and filled in the select menu for shipping nicely...
SO I guess make sure number of fields in both arrays are the same and delete fieldnames which you don't use from both arrays?!
Did the trick for me...
Still TYVM for you reply...
Glad to hear you got it working.
