looking at buying
Thread begun 5/05/2011 2:54 am by mr hankey | Last modified 5/05/2011 9:56 am by Jason Byrnes | 1496 views | 1 replies |
mr hankey
looking at buying
hi,
interested in buying this solution if it works.
only issue i have had is that i have not used many webassist extensions anymore and reverted back to older extensions due to issues when trying to apply them.
question is, can this be used with an existing system? database setup in place already?
also i have had to scrap using security assist as i always got cannot send session header errors when applying to pages even though i checked for white space which was the answer i got there was none so have had to use built in dreamweaver authentication. will it work with this or is this solution one that needs to site on its own and not part of an existing setup?
cheers
No, power mailer will not tie into your existing user database.
the registration built into Power Messenger is based on security assist, and will not work with the Dreamweaver authentication system.
