Restricting the number of uploads
Thread begun 5/04/2011 2:37 pm by Paul | Last modified 5/05/2011 3:52 pm by Jason Byrnes | 2217 views | 3 replies |
PaulBeta Tester
Using DFP and looking to limit my users upload capability to a value I set in each user record.
How might i apply an upload count value, incremented by one each time a user uploads and a new record is inserted into the upload sql table?
In the users table, you would need to create a column for upload limit.
then create a recordset to lookup the users upload limit.
then add an update record behavior, set it to update the users upload limit to:
<?php echo $row_RecordsetName['UploadLimit'] -1; ?>
this way, each time a file is uplaoded, upload limit will be reduced by 1.
now use server validation on the upoload form. For the server variable use:
Use number validation set the minimum to 1 and the maximum to 100
you will need to be careful of the code order on the page. The code orde will need to be:
recordset
Server Validation
Upload
Update record
PaulBeta Tester
Jason,
What can I say!
A quality response.
This is a perfect solution, it works.
Thankyou very much.
Paul.
no worries. Glad to hear it is working.
