Checkout Wizard
Thread begun 5/04/2011 12:28 pm by cicyou421883 | Last modified 5/17/2011 10:46 am by Jason Byrnes | 4408 views | 7 replies |
cicyou421883
Checkout Wizard
What file names are pre-populated by the e-cart Checkout Wizard.
I may have deleted some files.
I see:
checkout.php
checkout_failure.php
checkout_success.php
In addition, I need to know if I need to adjust the Checkout Wizard to new Authorize.net information - how do I do this. I tried to re-enter information and nothing happened... After entering the information, I saw that nothing was populating... Thanx
there should also be a confirm.php page.
if you select the option to include PayPal Express checkout, there will be a pp_confirm.php page and a pp_checkout_success.php page.
to edit the authorize.net settings after the checkout pages have been created, open the confirm page, and double click the eCart Local Checkout server behavior.
cicyou421883
found the confirm.php page
Thanx, found the confirm.php page. In server behavior, I do not see local checkout, just session Is that the same?
No, the set session variable behavior is not the same.
are you using Authorize.net SIM, OR AIM implementation?
cicyou421883
question on the php pages
In e-cart, open php page. In Dreamweaver CS5, started with index.dwt as my root. New page, page from templates to create a php save as page. products.php, - Used Dataassist to create the products pages (6). Used e-cart to create pages - shopping cart and checkout wizard.
Now back to index.dwt to make home page changes. Update links work find for all php pages. Cannot use e-cart add view cart to homepage when I select new page based on template and save as page from template index.dw. php. e-cart will not add view cart button to editable region. (greyed out) so e-cart does not put button over an editable region?
Do I have to start over? and make index.php as root? and eliminate index.dwt? or is there a way to get index.php to recognize all the php files linked to index.dwt. Index.php only sees links with template php files. Sitewide link change is not the answer either since index.php will not get the links.
How do I get e-cart buttons over the index.dwt editable region - tried. I need to edit the home page and enter e-cart in editable regions? or start over?
your template file:
index.dwt
needs to be a dynamic template:
index.dwt.php
to allow eCart to be applied to the template.
cicyou421883
Changed to indexphp.dwt.php
So I changed to indexphp.dwt.php I have files attached to that that update efficiently. cart.php (shopping cart name) is in my templates folder. products_Detail.php is in my templates folder. Followed turtorial linking to a detail page from a cart page. Opened cart.php which is in templates folder, url link, parameters, and ctrl, command save. Save products_Detail.php as name of product acai_Detail.php. save add to cart button on new page. can view local acai page, change quantity in add to cart. and the page blinks and just goes back to the page that is opened with quantity of 1. Bindings checked on acai_Detail.php page.... Also tried to create new folder in site called products and cannot use anything other than the ../acai_Detail.php.
Somehow the workflow is not correct. Do I have to have all of the template created pages outside of template? All of this is in relationship to e-cart bindings and server behavior and I cannot see why the add to cart just blinks to only the original acai_Detail.php page and is not linking to a detail page from a cart page. When I open template products_Detail.php, I save as new name acai_Detail.php and then change the bindings as per your tutorial on e-cart.
