can run two PowerCMS at once?
Thread begun 5/03/2011 1:42 pm by lee283140 | Last modified 6/01/2011 9:32 am by lee283140 | 2595 views | 3 replies |
lee283140
I installed PowerCMS for one client which was working fine. I then went onto my next client who wanted the same PowerCMS installing to their website. However after running the install for client 2. i could no longer login to clients 1 PowerCMS using their admin login. however i could login using the superuser on client 1 powerCMS but i cant edit anything. it just goes to the access check page and then reloads the admin index page.
No if i reinstall client 1. then client 2 has the same problem. I bought the developer version i im guessing you use the same serial number for all the PowerCMS i install.
Any help would be great.
Make sure you are using a separate database for each installation. It sounds like when you run the second install, you are setting it up to use the database.
lee283140
running two CMS at once
Thanks, but they are separate installs on separate databases. However they are both installed locally on my mac for testing. Ive had to put one on my live server as thats now complete and have one on my local machine which is being tested. it doesn't seem to be an isse with databases as when i had them both running locally and had one pointing to a DB remotely the problem was still there. but if i move the website aswell to the remote server and leave one locally its fine.
Thanks again i will just test one CMS at a time from now on.
lee283140
Cms
Still cant get to the bottom of this. could it be down to me using the same serial?
i purchased the the version of power CMS which stated i could use it on unlimited domains.
