Data Assist - Too Many Fields Defined
Thread begun 5/03/2011 1:10 pm by werecat321138 | Last modified 5/04/2011 10:54 am by Jason Byrnes | 4465 views | 3 replies |
werecat321138
I am getting the following error whenever I try to update or insert a file into an existing Access Database.
I used a different form insert for people to fill out and submit and it seems to work great but when I create the Admin features using Data Assist 2.08 I get the following:
Microsoft OLE DB Provider for ODBC Drivers error '8007000e'
[Microsoft][ODBC Microsoft Access Driver] Too many fields defined.
/2008Redesign/administrator/GeneralTitleInfo_Update.asp, line 57
Line 57 is: MM_editCMD.Execute()
I do have a very complex form that uses approximately 161 fields.
Is there a way to make this work?
I am using DreamWeaver CS 5
ASP model
It is a Microsoft Access file because, while it will be used, it probably won't get more than 200 records a year.
Any help would be appreciated.
this is a limitation to the microsoft Jet database engine.
The microsoft Jet database engine limits the number of output fields that a query can have to 255 columns. Similar to an access table, a query can have no more than 255 columns.
Note on UPDATE queries:
Note also that as the microsoft Jet database engine iterates through the records in an UPDATE query, it creates a field for the original value and a field for the updated value. When more than 127 fields are selected, it reaches the 255 field limit of a query.
werecat321138
Convert to SQL?
Hello,
If I convert to SQL would that solve the issue?
Yes, this issue is not present using an MSSQL database
