Permissable file types and file sizes
Thread begun 5/03/2011 12:02 pm by Paul | Last modified 5/05/2011 7:18 am by Jason Byrnes | 4792 views | 9 replies |
PaulBeta Tester
Does anyone have any suggestions as to how i might setup DFP to limit user file type uploads to .jpg and file size 50kb?
Thank you, Paul.
you need to use server validation from either Form toolkit or CSS Form builder for this.
for File type, use File Extension validation. For the Server varaible, expand the form collection and select the File Filed form element (the firsst plain one, not one that has a lightning bolt next to it.
for file size, select number validation, for the server variable, click the lightning bolt, expand the form collection and select the File Filed File Size variable.
Set the maximum to 500
PaulBeta Tester
Ok, applied that to my upload page.
Uploaded a file that breached my server conditions to test and my load page blanked out!
You wanna take a look at my file?
the obvious problem i see is code order from line 76 - 107
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos($_SERVER["HTTP_REFERER"], $_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"]) > 0) && isset($_POST))  {
$WAFV_Redirect "upload-error.php";
$_SESSION['WAVT_index_168_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect $_SERVER["PHP_SELF"];
$WAFV_Errors "";
$WAFV_Errors .= WAValidateFE(((isset($_FILES["imageField"]))?$_FILES["imageField"]["name"]:"") . "",".jpg, .jpeg, .png",true,1);
$WAFV_Errors .= WAValidateNM(((isset($_FILES["imageField"]))?$_FILES["imageField"]["size"]:"") . "",0,50,"",",.",true,2);
$WAFV_Errors .= WAValidateNM(WADFP_getImageWidth((isset($_FILES["imageField"]))?$_FILES["imageField"]:"") . "",0,480,0,",.",true,3);
$WAFV_Errors .= WAValidateNM(WADFP_getImageHeight((isset($_FILES["imageField"]))?$_FILES["imageField"]:"") . "",0,360,0,",.",true,4);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"index_168");
if (!function_exists("WADFP_getImageWidth")){
function
WADFP_getImageWidth($fileField){
$WA_ImageContentTypes = array("image/gif" => true "image/jpeg" => true"image/pjpeg" => true"image/x-png" => true"image/png" => true);
$width = -1;
    if(isset(
$fileField) && isset($fileField["tmp_name"]) &&  isset($fileField["type"]) && isset($WA_ImageContentTypes[$fileField["type"]]) ){
$dimensions getimagesize($fileField["tmp_name"]);
$width $dimensions[0];
    return
$width;
change that to:
function
$width = -1;
    if(isset(
    return
$width;
  if (
$WAFV_Errors "";
  if (
PaulBeta Tester
Got it!
I see now, my image width, being one of the validations, needed to run first in order for the validation to validate!
All working perfectly now.
Thank you for your speedy response.
Paul.
glad to hear it is working.
PaulBeta Tester
Quick question whilst on the validation tool topic.
How might i place the failed file upload parameter(s) on my error page
(if at all possible)
Using validation show if behaviors, you can show a different error for each validation that fails.
PaulBeta Tester
Thanks - will explore
you're welcome.
