Data Assist Error Message
Thread begun 5/03/2011 9:36 am by hbibizadeh396670 | Last modified 5/04/2011 7:23 am by Jason Byrnes | 2407 views | 3 replies |
hbibizadeh396670
I would like to filter a Recordset made by data assist.
However I get an error message:
Making this change would require changing code that is locked by a template or a translator. The change will be discarded.
How to I make these changes, an avoid this error?
Thanks in advance
The error you are getting is a common one when working with templates in Dreamweaver.
There is no solid fix for the issue, but I have discovered a workaround. See the following thread for details:
showthread.php?t=4509
hbibizadeh396670
I have had this problem in the past, so I know I will find this useful in the future as I do now.
Thanks a lot.
You're welcome.
